airfoil boundary condition
Old   June 25, 2006, 13:21
Default airfoil boundary condition
Bounecer
hello all; I'm writing a computer code simulating flow about an airfoil, in case of 2D, incompressible, laminar and viscous flow.Reynolds number equal 2x10**3. Governing equations were adimentionalised by setting U=u/ue and V=v/ue, .......(ue is the upstream velocity) My question is about the boundary condition at upstream, is it U=1, or U=Re*visc/C Re: Reynolds number Vis: Kinematic vicosity of air C: Corde
Thanx
Old   June 26, 2006, 00:39
Default Re: airfoil boundary condition
ganesh
Dear Bouencer,
The upstream BC should be U = ue/ue = 1. The kinematic viscosity would then become Vis/Re, after non-dimensionalisation.
Regards,
Ganesh
Old   June 26, 2006, 11:27
Dominic
Yes,
Ganesh is right. Also, to add more :
u said:
" is it U=1, or U=Re*visc/C"
It should be u=Re*visc/C and not 'U'. Here 'u' has dimensions. But U doesnt have. If u calculate 'u' based on the above Re and divide by ue, u shud get '1' at the upstream.
regards,
Dominic
Old   June 26, 2006, 15:29
Bounecer
Thanx Ganesh, Please i've an other question: I'm using C-grid generation, so the upstream side in physical domain become the top side in computational domain, how to write the boundary condition U=1 (condition in physical domain in terms of cartesian coordinates) in computational domain where i must express U in terms of the new curvillinear coordinates ksi and eta
Old   June 27, 2006, 00:43
Dominic
If U' represents the solution in computational domain, and U in the physical domain then,
U' = [T] U, Where [T] = | d(x,y)/d(ksi,eta) |
T(1,1)=dx/dksi ; T(1,2)=dy/dksi ; T(2,1)=dx/deta; T(2,2)=dy/deta;
Here [T] is the Jacobian of the transformation..
Knowing U, you can compute U'...
regards, Dominic
Old   June 27, 2006, 06:17
Bounecer
thanx Dominic; If y're agree i'll send you the mathematical model in cartesian and curvillinear coordinates with descriptions, the finite volumes steps discretization and my code program in Fortran.
Old   April 12, 2012, 13:06
Default iii
fatimah
imah is on a distinguished road
hai all.. im also writting computer code using fortran.. i try to simulate airfoil in c-grid.. my problem is.. i not sure the boundary condition at double connected grid (after the trailing edge).. hope u all can help me.. thanks..
imah is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
airfoil boundary condition Bounecer Main CFD Forum 6 June 28, 2010 10:24
problem with boundary condition??? smn CFX 5 November 24, 2009 07:37
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
