3D axisymmetric flow in cylindrical coordinate = 2D cartesian flow? |
Rep Power: 13 ![]() |
Hi All,
I'm simulating a axisymmetric flow in 3D cylindrical coordinate. Since it's axisymmetric, I'm thinking if I can re-write the code in 2D cartesian, just by looking at one plane with constant azimuthal angle. The governing equations in 3D cylindrical coordinate has additionally terms like ![]() My question is, now it seems to me that the governing equations are different for this same problem. I know this may sound absurd, could any one explain it? Thanks. Shu |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
but the axi-symmetric geometry does not imply the same simmetry in the flow... that is realized for laminar steady flows as well as for statistically averaged turbulent flows but, in general, the flow can be fully three-dimensional also for symmetric geometries ...
#4 | |
Could you be more specific? What will you deal with those f/r terms? In 3D cylindrical coordinate, they are singularities, while in 2D, no such problem. Thanks. Shu |
#5 | |
I have some problem following what you said... Do you think I can do 2D cartesian for 3D axisymmetric flow? What physics will I lost when I do this? Thanks, Shu |
#6 | |
The flow solution in DNS/LES/URANS can not be modelled correctly by simmetry conditions |
Philipp
Rep Power: 27 ![]() |
If you have 3d axis-symmetry it means that you have a rotational body and also the flow is rotationally symmetrical. You can not model this by 2d cartesian coordinats, because this a complete different symmetry. If you use 2d axisymmetric then you will indeed get exactly the same result.
The skeleton ran out of shampoo in the shower. |
#8 | |
onset of instability can destroy the rotational flow symmetry even for a geometrical symmetry (just think of a flow around a cylinder at Re>40 - 50)...this happens, for example, in round jets, in pipes, etc. In turbulent statistically steady flows, you can use RANS formulations and recover the symmetry but you solve for a statistical field. |
#9 |
Rep Power: 15 ![]() |
He isn't asking about whether or not have can assume axisymmetric flow, he is asking how to write down the equations. If the flow is axisymmetric you can indeed reduce the problem to two dimension, however you are not reducing it to Cartesian coordinates. You will still have the 1/r terms in the equations to deal with. Basically take the full 3d cylindrical equations and set all of the terms with either a theta velocity or a theta derivative to zero and you will get you new set of equations. The 1/r terms don't cause singularities if your boundary conditions are correct.
#10 |
Philipp
Alright, now it makes sense. Shubiaohewan, all the terms f/r are terms, where f is the derivative of something. Now, for r->0, also f->0 (due to the symmetry). If you rummage in your memmory and use de L'Hospitals rule, you will see, that the (dy/dr)/r for r->0 actually is the second derivative, dy^2/dr^2, in axisymmetric cases. So for the inner points, where r=0, you have a different set of equations, because you need to discretize second instead of first derivatives. All fluxes are zero there.
#11 | |
I agree but I would remark that using symmetric conditions requires some knowledge about the type of flow to solve for. Depending on the physics, you can realize a simulation both in the (r,z) and (r,theta) planes. Or you need to solve the 3D flows ... |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Two phase flow in cylindrical coordinate | hilllike | Main CFD Forum | 10 | September 1, 2013 21:32 |
cylindrical coordinate -Gambit | noussa | ANSYS Meshing & Geometry | 2 | June 12, 2010 09:07 |
Star-CD Cylindrical coordinate | hamoudi | STAR-CD | 4 | April 29, 2009 11:11 |
