#41 |
Thanks Praveen!!
#42 |
Ruben OP:
I'm writting a code for solving the Euler equations of compressible flow. I'm interested in state state solutions and I have problems with the oscillations. Even in the subsonic case I have spurious oscillations and the convergence is too slow. I think that I need a time integration scheme with damping. What scheme can I use? ------ diaw comments: After all has been said & argued on this thread, & after spending a while reviewing both Euler & Potential derivations & equations forms, I must say that I fail to see a useful valid connection between the two. Potential flow: Irrotational flow => transform via u=d(phi)/dx ; v=d(phi)/dy => d2(phi)/dx2 + d2(phi)/dy2 =0 Euler flow (weak form): d()/dt + u.d()/dx + v.d()/dy = f(x,y,t) The two are completely different animals: 1. The Laplace equation is going to either decay/grow in time, if a d(phi)/dt is bolted on & dependent on the sign used & possibly some forcing function. If in steady form, then we have a nice smooth shape. 2. Euler eqn is a convection flow which is inherently unstable & wants to produce instability, waves & the like. Not too smooth at all... If you really begin to look deeply into the physics of what these forms actually represent, they are very different. I have no doubt that the OP sees waves - & so he should with a good algorithm. It is a poor algorithm that adds unwanted numeric viscosity. diaw... |
#43 |
Thnaks for your comments diaw.
#44 |
m p
Rep Power: 15 ![]() |
what are the correct boundary conditions for this problem? we need 4 in 2D .among them one is extrapolation which I use riemann invariant extrapolation,but what are the others when we have the inlet mach number?
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
plz help,urgent, vof model steady state | Garima Chaudhary | FLUENT | 4 | March 15, 2018 12:22 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
steady state, laminar vof_model | Garima Chaudhary | FLUENT | 0 | May 24, 2007 03:11 |
