implicit scheme for time step
Old   June 21, 2006, 01:43
Default implicit scheme for time step
vivian
Hi,everyone,
I want to use high-order implicit scheme for time step. Which kinds of scheme should I choose for shock capturing?
Thanks!
vivian
Old   June 21, 2006, 13:01
Default Re: implicit scheme for time step
ztdep
I thint to chature the shock, one need a high resolution space shemem! am i right!
Old   June 21, 2006, 22:38
vivian
Thank for your reply!
Yes!I think using the high-scheme for space is important. Do you think the high-scheme for time is also important or less important than high-scheme for space or can be ignored for shock capturing?
vivian
Old   June 22, 2006, 02:27
khai ching
It depends on the time nature of your problem. If you are concerning about steady-state solution, high-order scheme for time is less important and you should devise a time-marching scheme which can result in rapid convergence(good damping property). For real transient case, of course, higher-order scheme is attractive in terms of resolving the unsteadiness.
For shock-capturing purpose, I presume that spatial differencing scheme plays a very important role. It is crucial not only in the subject of numerical accuracy(high-order scheme) in order to allow us to resolve the shock wave sharply, the scheme must be bounded in the sense of it won't create spurious oscillations in region near the flow discontinuity, which is always the main issue of the implementation of high-order scheme.
-khai ching-
Old   June 23, 2006, 04:47
vivian
Thank you for your reading!
I found the resonant oscillation in my tube was not stable under the resonant frequency.It is not agree well with the literature. Is it the reason of scheme of time or other reasons?
vivian
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Implicit Residual Smooth of Jameson Scheme hhuang84 Main CFD Forum 0 November 7, 2010 10:44
How to choose the CFL number with implicit scheme? D.T. Main CFD Forum 2 October 23, 2002 14:56
Implicit Scheme for 1-D nozzle flow Yogesh Talekar Main CFD Forum 1 June 8, 1999 10:49
