hankel negative order
Old   June 16, 2006, 06:06
Default hankel negative order
sankar
HI all, I am using hankel functions, and come across a probelm in Matlab while applying for negative order. eg: besselh(-7,0.05)
ans =
-2.2976e-003 +3.7553e+013i
But i found some error when checked using the formula given in Abramowitz & Stegun (class 9.16) which is the source for this H(-n,z) = exp(n*pi*i)*H(n,z) where n is order and z is argument
>> exp(7*pi*i)*besselh(7,0.05)
ans =
2.9895e-002 +3.7553e+013i
even though the imaginary part is same..there is some error in real part.For certain orders this is working good in matlab. can any one comment on this which one to use.. Is there any fortran code to handle negative order
sankar.
Old   June 16, 2006, 07:12
Default Re: hankel negative order
Tom
A play with a calculator should make you suspicious since
H_n(x) = J_n(x) + iY_n(x)
Now for n=7 and x=0.05 we expect J_n(x)~1.21e-15 and Y_n(x)~-3.755e+13 (lead order term in asympotic series as x->0 - which is a good approximation because of the relative largeness of n).
Now exp(i.n.pi) = -1 so H_n(x)~-1.21e-15 + i.3.755e+13.
Tom.
1st order vs 2nd order ken FLUENT 8 March 14, 2013 04:43
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
blockMesh error ... balkrishna OpenFOAM Pre-Processing 0 August 17, 2010 03:39
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
