Mesh element size
Old   April 16, 2013, 06:30
Smile Mesh element size
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello sir,
In my analysis flow between two parallel plates(one plate is heated and another one is cooled) i am interested to know what is the temperature at middle of these two plates .and volume avg temperature.but in this case wall temperatures and near wall temperature are not so impotent for me. my question is
1.is it required to specify element size to capture boundary layer(i am not interested to know temperature values at boundary layer)
2.is there any change in solution (with and without considering of temperature).
Thank you sir
Sunil Patil
sunilpatil is offline   Reply With Quote
Old   April 16, 2013, 21:41
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
I need to know the flow is fully developed or not.
if it is fully developed, the velocity distribution has a parabolic profile, and the temperature distribution can be obtained by solve the energy equation in an analytical way.
if it is not fully developed, the NS equation is solved first to obtained the velocity field, then the energy equation is solved to obtain the termperature field.
if the buoyance effect need to be taken into account, the NS and energy equation should be solved simutaneously.
ztdep is offline   Reply With Quote
boundary layer, element size
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
