June 11, 2006, 23:36 |
jobs??
Anyone in singapore needs a CFD engineer? please contact me
June 12, 2006, 10:16 |
Re: jobs??
have you tried the obvious: NUS, Temasek labs, DSO, ... ?
June 12, 2006, 11:17 |
Re: jobs??
I assume your temasek lab means ASTAR lab, yes found that ASTAR only employ ppl with either master or PHD holders, not normal degree engineer like me. How sad. I expect NUS and DSO to be the same situation (unless u disagree). anyway, they arent advertising for cfd engineers.
there is a company call aqua blu technologies advertising for engineer (CFD), but it didnt reply me when i wrote to it. Anyone any idea? |
June 12, 2006, 11:43 |
Re: jobs??
I think you will probably find that it is the same globally, without a PhD or at the very least a masters you will really struggle to find your way into CFD, you will probably be ok if you have a lot of industrial CFD experience but the key is that you need to prove that you have the knowledge, without one of the three you will struggle and your best bet to get into the industry (if you dont want to go via the accademic route) is to find a general engineering job with a little CFD experience, then try and build the experience up.
June 13, 2006, 13:43 |
Re: jobs??
June 13, 2006, 13:49 |
Re: jobs??
Not everywhere. Maybe you are thinking about research, but for application of CFD for aerodynamic design, you shouldn't have too much trouble getting a job even without a Masters ...at least in the US. |
June 14, 2006, 11:18 |
Re: jobs??
Aerodynamics design with CFD experience --- Yes.
CFD Analyst --- No! Minimum master degree in US. |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 23:51 |
multiple parallel jobs on one machine | joeybernard | CFX | 0 | December 16, 2010 11:10 |
Random machine freezes when running several OpenFoam jobs simultaneously | 2bias | OpenFOAM Installation | 5 | July 2, 2010 08:40 |
Running Jobs in Batch Model | RP | FloEFD, FloWorks & FloTHERM | 3 | April 16, 2008 08:47 |
Running 2 CFD jobs on one PC | steve podleski | Main CFD Forum | 17 | February 16, 2000 15:40 |
