April 11, 2013, 21:36 |
Parallel Processing in OpenFOAM
musaddeque hossein
Rep Power: 18 |
Dear all:
I have a question on mpi. After the processing is complete, does mpi send any flags that can be trapped -- i.e. used to trigger an external program? I need have a code that needs to be triggered once the processing is complete (before recomposePar). Where can find some information on this? Unlike ./Allrun , ./Allclean, mpi processes run in the background and does not hold up the system, so there is no discernable signal that tells OpenFOAM "I am done". |
interdymfoam, mpi, system calls |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 09:53 |
[mesh manipulation] Problem with RenumberMesh in parallel in OpenFOAM 2.1.1 | srini_esi | OpenFOAM Meshing & Mesh Conversion | 1 | November 8, 2013 03:48 |
Parallel solution in OpenFOAM | makaveli_lcf | OpenFOAM Running, Solving & CFD | 0 | September 21, 2009 09:07 |
Question about ghost cells in parallel processing | vishwas | Main CFD Forum | 3 | March 12, 2006 22:46 |
Paradox in parallel processing | Vagelis | FLUENT | 0 | October 26, 2005 06:36 |
