Wind turbine simulation
Old   June 8, 2006, 04:26
Default Wind turbine simulation
Saturn
Hi folks,
I have a problem about the rotating simulation of wind turbine.
I usually use the RFR or MFR to simulate rotating of fan, but in the wind turbine case the wind flow work is done on the blades to make the blades rotating.
In the RFR or MFR case, the rotating rate is applied to simulate the rotating of the blades.In the wind turbine case, I only have the data of wind flow at 6 m/s.
How do I simulate the wind flow work is done on the blades and then blades rotating?
Thanks!
Old   June 12, 2006, 04:57
Default Re: Wind turbine simulation
san
Go to google and search for "WIND TURBINE" you will get many websites.
Few companies have posted the working range turines ( at sspecified conditions), manufactured by them. I hope this will help you.
also you will find few papers on this subject in pdf format.
I was looking wind turbine geometry from many days. can you share the details of geometry.
This will be very help full to me.
my email-id is
rsan_2001@rediffmail.com
with regards san
please help in simulating a wind turbine blade in 6 DOF ????.... usman naseer Main CFD Forum 2 March 10, 2016 03:53
Torque of wind turbine simulation caohan FLUENT 8 August 12, 2014 00:01
HAWT, should we use sliding meshes? or the UDF? f0208secretx FLUENT 11 February 19, 2012 06:58
wind turbine simulation, Ansys Post results question Laions CFX 7 September 20, 2011 06:13
3D simulation of wind turbine in Yaw wind(in a lateral wind) mohammad Main CFD Forum 0 December 28, 2010 04:26
