system coupling ansys 14 - error
Old   April 10, 2013, 10:00
Default system coupling ansys 14 - error
karuppasamy
karupps8 is on a distinguished road
Hi friends,
While solving the solution for 2-way Fluid Structure Interaction problem with the option SYSTEM COUPLING in ANSYS 14.0 i got an error after completion of the iterations.
The error is as follows :-
"Update of the solution component in System Coupling failed: Update of the Solution component in System coupling did not mark container as updated (final state is OutOfDate)."
Is this problem solvable ?
THANK YOU
karupps8 is offline   Reply With Quote
Old   May 20, 2014, 22:36
Default from fluent manual
saleh Gharaie
saleh_1_2 is on a distinguished road
In order to have changes made in Fluent systems propagated to downstream System
Coupling systems, save your project, synchronize with Workbench, or close Fluent. This will
ensure that the information passed to System Coupling matches settings in Fluent. If this is
not done, the analysis may be allowed to run but the following Workbench state error will
be issued at the end of the run:
Update of the Solution component in System Coupling failed: Update
of the Solution component in System Coupling did not mark container
saleh_1_2 is offline   Reply With Quote
ansys 14.0, fsi, fsi mesh, system coupling
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
