How to solve an eigenvalue problem with a constant? |
April 6, 2013, 05:24 |
Rep Power: 13 |
April 6, 2013, 05:48 |
Filippo Maria Denaro
Rep Power: 73 |
Maybe I do not understand well your question ...but if you have an eigenvalue \lambda and q is an eigenvector, then it is required that the vector a is parallel to q, right?
April 6, 2013, 11:46 |
#3 | |
Rep Power: 13 |
Thank you. I start to understand what you mean by a should be parallel to q. BUt in general, a could make any angle w.r.t q. Since q is unknown for the moment, we don't know what's the angle a makes with q... Shu Last edited by shubiaohewan; April 6, 2013 at 12:47. |
April 7, 2013, 02:00 |
April 8, 2013, 12:25 |
#5 | |
Gerrit Laube
Rep Power: 13 |
Anyway, there are n for which you will not only find one but infinitely many solutions. These are the Eigenvalues and these are the same as in because Eigenvalue only means "the value of that makes linearly dependent". You will find a linearly dependent matrix by setting its determinant to 0, which is the "characteristic equation" you might have heard of. In that case, an Eigenvector is one of these infinitely many solutions (e.g. if the Eigenvector for a 2x2 matrix is [1;2] it could also be [2;4] and so on). Back to your question: You could find some kind of Eigenvector and Eigenvalue, which is the same as in the original Eigenvalueproblem and additionally you will find infinitely many other solutions for infinitely many other . In the real Eigenvalueproblem, these infinitely many solutions are all 0, which is why you search for the only non-zero solution. But in your case most of them will be non-zero solutions and only you are able to know what this might mean. My hones advice: You should check if this equation is really what you want/need to solve! Good Luck! |
how to solve large scale problem | send1000 | ANSYS | 0 | September 3, 2011 14:46 |
how to solve a problem involving both laminar and turbulent flow | seefd | FLUENT | 1 | June 3, 2011 04:20 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Can FLUENT solve this type of problem? | Whitaker | FLUENT | 3 | October 23, 2000 04:01 |
use of MAC method to solve sloshing problem. | S.R.SAHI | Main CFD Forum | 1 | April 15, 1999 23:28 |
