How to create Rotating Frame of Reference?
Old   April 4, 2013, 22:59
Default How to create Rotating Frame of Reference?
waqas khalid
waqas khalid is on a distinguished road
i am doing CFD analysis of Kaplan Turbine to do that i have to make rotor as rotating body while wall outside the rotor as stationary. i have already made rotor as rotating wall and outside wall as counter rotating wall in no slip default domain but this message keep on showing every time i run execution: plz help!
| ERROR #002100080 has occurred in subroutine CHECK_NORMV.
| Message:
| The specified velocity vector on the boundary patch
| rotor
| has a significant normal component at one or more faces. One of
| these face locations is
| (x,y,z) = ( 1.69413E-01, 1.80352E-01, 4.24567E-01).
| The angle between the specified velocity and the element surface is
| 77.622 degrees at this face. This is considered an error because
| it implies that the mesh is moving. The following are possible
| reasons for the error message:
| 1. There is a setup error; for example, an incorrect axis of
| rotation.
| 2. There may be a meshing problem; for example, the nodes on a
| rotating surface might not lie on the surface of revolution.
| 3. The boundary is curved and the mesh is very coarse. In this
| case, you may modify the tolerance by increasing the
| expert parameter 'tangential vector tolerance wall'
| from its default of 20 degrees.
waqas khalid is offline   Reply With Quote
rfr, rotating machines
how to get relative velocities in a rotating frame of reference? alkochevsky OpenFOAM Post-Processing 14 May 31, 2017 07:05
How to create the rotating reference frame of a MRF problem in DesignModeler wrt to t Zev Xavier FLUENT 1 May 11, 2012 04:59
Boundary conditions for rotating reference frame Borna OpenFOAM 1 August 24, 2011 11:25
rotating frame of reference and total pressure viking ANSYS 1 November 24, 2010 00:25
Stirred tank with baffles simulation using single rotating reference frame M.Zhou FLUENT 1 March 5, 2000 16:01
