Lift & drag coefficient for NACA airfoil's for VAWT application
Old   April 3, 2013, 03:36
Default Lift & drag coefficient for NACA airfoil's for VAWT application
M. Abdul Akbar
akku is on a distinguished road
Dear All,
My PhD work is based on Vertical Axis Wind Turbine's (VAWT) for which I need tabulated (experimentally validated) lift and drag coefficients for NACA airfoil's corresponding to low Reynolds number of flow (typical of what is experienced by VAWT's).
I am currently referring to the report from Sandia National laboratories:
Robert E. Sheldahl, Paul C. Klimas.Aerodynamic Characteristics of Seven Symmetrical Airfoil Sections through 180-Degree Angle of Attack for Use in Aerodynamic Analysis of Vertical Axis Wind Turbines. Sandia National Laboratories energy report: SAND80-2114;1981
Is there a better reference than this ???. This documentation is very old (1981) and also contains data for only seven symmetrical airfoil’s. More importantly is there any correction to the values in the document (considering the time span that has elapsed)??.
Looking forward to responses,
Thanks in advance
akku is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
airfoil lift and drag coefficient amir_14 FLUENT 5 January 1, 2013 09:30
Drag and Lift coefficient for diffusor rego STAR-CCM+ 3 May 7, 2012 19:05
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
