flow over sphere
Old   June 1, 2006, 13:34
Default flow over sphere
senthil
hi i am trying to bench mark flow over spher problem with experimental results. The drag coefficent what i am getting with cfd is not matching with experimental. Any boby can guess. the flow field is steady, 3d, Laminar and Reynold no is 100. Thanks in advance.
Old   January 30, 2010, 12:50
khurram
kr63 is on a distinguished road
Hi
you should check where the transition and separation is taking place in both casses.
kr63 is offline   Reply With Quote
Old   January 30, 2010, 14:04
DoHander is on a distinguished road
On the same mesh do a turbulent simulation and check your y+ if this is larger then 1, the n you are not properly solve the boundary layer region.
You can create your mesh in order to have a y+<1 and then do again the laminar calculation - also try steady vs. unsteady. You can find here on cfd-online a good y+ estimator.
Do
DoHander is offline   Reply With Quote
Flow past a sphere Fabio FLUENT 23 December 18, 2009 16:32
flow across sphere at Re=10,000 raheelrasool Main CFD Forum 3 April 19, 2009 23:31
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Modeling diffusion of cell (sphere) under flow Shel Main CFD Forum 0 August 22, 2005 16:26
3D sphere flow MH Kim Main CFD Forum 1 August 8, 2005 18:06
