Non-uniform inlet velocity application in Fluent
Old   August 11, 1999, 10:05
Default Non-uniform inlet velocity application in Fluent
ghlee
Dear Friends! I have used Fluent ver5.1, and I will calculte the centrifugal type turbomachinery. In computation, I have to apply the inlet boundary condition (non-uniform velocity condition). But I can't find the proper menu bar. Would you like to give me informations. Thank you for reading.
p.s. I had the manual of Fluent ver4.x
Old   August 11, 1999, 18:04
Default Re: Non-uniform inlet velocity application in Fluent
John C. Chien
(1). I have not started using the new version of the code. (2). But you can get into the help menu item to find out more about the inlet boundary conditions. Most vendors have move the hardcopy user's guide into the help menu. Sometimes, to use it , you need to open the Netscape ( or the like) first. So that it can display the text there. (3). I am just guessing that, you need to prepare the non-uniform profile in certain format as an input file. And later, when you specify the inlet conditions, you can select the user-defined option and read in the inlet profile file.
Old   August 11, 1999, 22:32
Sung-Eun Kim
"Profile" file is what you need. Please check out the on-line help (See inlet BC section or search for "profile") in FLUENT, if you don't have user's guide. Here's what you have to do.
- Write a profile file where you specify the profiles of the solution variables of your choice (the format is desribed in user's guide) - Read in the profile file into FLUENT - Go to BC panel and choose the profiles for the solution variables you want.
And you're all set. Please contact ATES and get some help if you run into dificulties.
pressure not uniform although velocity is uniform at the inlet swati_mohanty FLUENT 7 March 8, 2016 01:19
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 05:32
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 05:56
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
