CFD Anderson.. Chapter 10: Supersonic Flow over a Flat plate |
August 14, 2013, 10:34 |
c code
#21 |
Kerala
i also need the code please sent me sreekonchira@gmail.com
August 21, 2013, 18:31 |
#22 |
shashi kumar
can u send me a copy to me at karankumar9931034374@gmail.com
October 17, 2013, 15:55 |
M25 case for supersonic flow at 200,000ft
#23 |
sandy
Rep Power: 13 |
Has anyone done the second case in Anderson CFD book ?
Mach=25 Alt=200,000ft (60km) L=0.005; I tried it and it gives me complex numbers. i used the free stream properties at that altitude. I used the same 70*70 grid . should i be missing something ? |
February 11, 2015, 10:44 |
Matlab code
#24 |
Rep Power: 14 |
I have uploaded a Matlab code that solves the original problem. It can be downloaded from MathWorks here: http://www.mathworks.com/matlabcentr...r-a-flat-plate Hope this helps! |
July 11, 2020, 02:17 |
C code
#25 |
Srijit Sen
Rep Power: 8 |
Can you please send the code to srijitsen98@gmail.com Thank you!
supersonic flow |
Low Reynolds Number Flow over a Flat Plate | Go | FLUENT | 4 | August 28, 2013 06:19 |
Flow over a flat plate | vasanthkch | OpenFOAM | 1 | December 19, 2011 15:57 |
2d supersonic flow over flat plate | puzzled | Main CFD Forum | 2 | March 17, 2004 19:07 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
Turbulent flow over flat plate | Narayanan | Main CFD Forum | 1 | May 8, 2000 08:03 |
