March 21, 2013, 06:48 |
Angle of attack not changed
AndreiCFD
Rep Power: 14 |
Hi Foamers
I am simulating the flow over NACA23012 and it seems that when i change the angle of attack i am getting the same results. for example i changed from 0 deg to 5 deg using the Velocity*cos(angle) in x direction and Velocity*sin(angle) for y direction but the results seems to be the same even after i defined the angle of attack ..weird............. Might my inlet faces....what do you think? Any suggestions......? Thanks |
March 21, 2013, 07:14 |
Alex
Rep Power: 49 |
What does your computational domain look like? What other boundary conditions do you have besides the velocity inlet?
A sketch or even a screenshot might be helpful. And which soler are you using? |
March 21, 2013, 07:33 |
#3 | |
AndreiCFD
Rep Power: 14 |
below i attached my sketch and sorry for the poor quality but you can understand ... I am using k omega sst and simpleFoam. solver the wall represents my domain ... The inlet is defined 10 meters away from the wall and the outlet is defined 15 m away from the trailing edge....... Thanks again |
March 21, 2013, 08:41 |
Lefteris
Rep Power: 16 |
And the chord length is? I mean, if the chord is 1m in length I believe the boundaries are too close. They should be at approximately 20c away.
Something else, I don't know how openfoam works, but you should check whether it uses angles in degrees or in rads.
Lefteris |
March 21, 2013, 09:04 |
Alex
Rep Power: 49 |
Just like I thought...
The straight boundaries (symmetry I guess) at the top and bottom of your domain guide the flow towards an AoA of 0°. No matter what you specify at the inlet. |
CFX convergence problem simulating ogive-cylinders at varied angle of attack | jdacosta | CFX | 6 | February 25, 2015 22:42 |
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 01:37 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | CFX | 2 | December 24, 2008 12:00 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 09:18 |
