governing eq's for flow over wedge problem?????
Old   May 21, 2006, 04:39
Default governing eq's for flow over wedge problem?????
vijesh joshi
Hello everyone. I am intersted in writing a code for "flow over a wedge at hypersonic conditions" problem to get some coding experience. I want to solve Euler (inviscid-compressible)eq's for the problem. Other than Continuity, momentum and energy eq's whether turbulent eq's have to be taken into account? Please help. Thanks in advance. Regards VVJ.
Old   May 21, 2006, 10:22
Default Re: governing eq's for flow over wedge problem????
ganesh
Dear Vijesh,
If you are making use of Euler equations, the concept of turbulence does not arise at all. Turbulence is intimately linked with the N/S equations, so the question of turbulent equations and suitable models arise only for viscous flows, and only if Re is in the turbulent regime. There is lot of literature for these in the hypersonic regime, for your information. Anyway, if you are a beginner looking for coding experience, I suggest you start with something simpler, and in any case Euler equations and turbulence together makes no sense.
Hope this helps
Regards,
Ganesh
Old   May 21, 2006, 11:24
diaw
That's what I felt, Ganesh... good points.
I would direct Vijesh to boundary-layer theory which is well established if he wants to work within the boundary layer itself - at high free-stream velocities. As you know, this analysis becomes an ODE & can lead to some very interesting analyses. It all depends on where he intends to research.
Most Euler analysis assumes inviscid flows at surfaces.
It is useful to study the full N-S at much lower speeds & try to understand the instability & turbulence mechanisms. If modeled correctly, the flow regime can be observed to split into the boundary-layer & 'Euler-like' regimes. A very interesting area indeed. Needs a strong computer.
diaw...
Old   May 22, 2006, 00:45
Vijesh Joshi
Thanks Guys. I will use your suggestions for my future works. Regards VVJ
Old   May 22, 2006, 02:27
Rami
Just an additional note: One point that is usually overlooked in the difference between "supesonic" and "hypersonic" regimes is that in the latter chemical reactions due to the air dissociation are taking place. Unless these are modeled, your model is not hypersonic, but rather a higher Mach No. supersonic model.
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
