SSIIM- F 36 2: computation of the vertical water surface elevation
Old   March 19, 2013, 11:44
Default SSIIM- F 36 2: computation of the vertical water surface elevation
Miss Mummputz
Mummputz is on a distinguished road
Dear all!
I have a channel with cross- bars where I'd like to use the F 36 2 function to compute the vertical elevation of the water surface with SSIIM 1. However, due to the cross- bars, this function is extremely unstable and diverges. I don't know how to stabilize it- do you have any idea?! I already tried to make a very fine mesh of straight rectangles- it didn't work..
The computation does work with the F 36 0 function, but is far too inexact and does not create the real water surface elevation which was measured in the pilot experiment.
thanks a lot for your help!!
Mummputz is offline   Reply With Quote
Old   July 1, 2015, 05:14
hani
helm is on a distinguished road
hi dear.
does your problem answerd?
helm is offline   Reply With Quote
Old   July 1, 2015, 05:52
hani
hi dear.
do you active still in frume?
does your problem answered?
Spillway Analysis Fixed Water Surface Boundary Condition mgdenno OpenFOAM Running, Solving & CFD 17 December 9, 2018 18:37
SSIIM 2, vertical elevation of the water surface, transient water flow parameters Mummputz Main CFD Forum 6 November 18, 2012 14:39
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Gravity Flow Velocity Computation Jerry McHugh Main CFD Forum 1 March 16, 2007 14:24
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 07:33
