May 19, 2006, 11:48 |
smoothing iterations before restriction
Dear CFD People,
I would like to learn how many smoothing iterations are necessary before restriction (transversing from fine-to-coarse grid) and after prolongation (transversing from coarse-to-fine grid) while solving Euler and Navier-Stokes equations with (a finite volume scheme, Runge-Kutta time integration, Roe scheme, local time stepping) FAS Multigrid and FMG algorithm. Regards. |
May 20, 2006, 01:06 |
Re: smoothing iterations before restriction
Hi: I come across a case b4 whereby implicit residual smoothing is indeed necessary before the residual is prolonged to fine grid level to ensure multigrid efficiency. However, instead of Roe scheme, I am applying the NVF schemes for convective discretization. For that purpose, 2-3 iters are fine..
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 13:53 |
