May 19, 2006, 06:44 |
linearization of k-e source terms
Hi: APpreciate if anyone could enlighten me on this:?
(1) What are the standard techniques designed to linearize the source terms for the k-e equations? Could anyone please advise on the available references? (2) If I would like to include the buoyant terms into the k-e source term, what would be the correct implementation? Any idea on how to make the buoyant term more "implicit", i.e. transfer that to the main diagonal of the coefficient matrix? TQ -khai ching- |
May 19, 2006, 15:50 |
Re: linearization of k-e source terms
Dear khaiching,
There is a paper by Prof. Dick's group on linearisation of source terms for k-epsilon and k-w equations. I can mail it to you if you give your mail id Regards, Ganesh |
May 20, 2006, 01:08 |
Hi Ganesh, my email id is: ngkhaiching2000@yahoo.com. Thanks for your help..
July 10, 2009, 07:17 |
Aram Amouzandeh
Rep Power: 17 |
Hi Ganesh!!
I would kindly ask you to send me the paper on linearisation of source terms of k-epsilon equations by Erik Dick s group: aram.amouzandeh@tuwien.ac.at Thx in advance, Aram |
July 10, 2009, 10:22 |
sample of fortran program
Asghar
Rep Power: 17 |
source_kEx(ij)= gen ! explicit source of k
source_kIm(ij)= -Cmu(ij)*k1/ (nut(ij)+.000000001) ! implicit source of k cturb1 = 1.44d0 ; cturb2 = 1.92d0 k_t0 = k_t(ij)+.0000001 ep_0 = ep_(ij) source_eEx(ij)= cturb1 * ep_0 / k_t0 * gen ! explicit source of e source_eIm(ij)= -cturb2 * ep_0 / k_t0 ! implicit source of e . . . ! source term k do ij=1,no_nodes k_t(ij) = ( k_t(ij) + source_kEx(ij) *dt) / (1.-dt*source_kIm(ij)) enddo ! source term e do ij=1,no_nodes ep_(ij) = ( ep_(ij) + source_eEx(ij) *dt) / (1.-dt*source_eIm(ij)) enddo |
July 11, 2009, 05:26 |
Mohammad Reza Hadian
Rep Power: 17 |
would you please put the full title and address of the paper here?
May 23, 2013, 03:46 |
Rep Power: 15 |
Hello together,
even the thread is old I hope somebody is reading it I want to add a source term in the epsilon equation in the k-epsilon-model The term is: 4 * k * C_mu * HLP with: HLP = (du/dx)^2 + (dv/dy)^2 + (dw/dz)^2 + 1/2 * (du/dy + dv/dx)^2 + 1/2 * (du/dz + dw/dx)^2 + 1/2 * (dv/dz + dw/dy)^2 After adding this term to the epsilon-equation it looks like: + fvm::SuSp(4.0*k_*Cmu_*magSqr(symm(fvc::grad(U_)))/(epsilon_+const), epsilon_) with const = dimensiond scalar (1e-05) to avoid dividing by 0 Is it correct to implement this term like this? Iīve read: http://www.cfd-online.com/Wiki/Sourc..._linearization but I donīt know how to divide my term in a constant and a linear part. Can anybody help? thanks a lot greetings Idefix |
June 6, 2013, 12:00 |
Prof. Dick's paper
#8 | |
ali
Rep Power: 14 |
It would be my pleasure if you send me that paper via e-mail. My e-mail: ali_or_aero@yahoo.com |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
Using source terms | jsm | Main CFD Forum | 4 | August 20, 2009 07:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
