Impinging Air Jet On Flat Plate for Cooling(Please Help)
Old   March 16, 2013, 18:07
Default Impinging Air Jet On Flat Plate for Cooling(Please Help)
Fırat
Overdosed is on a distinguished road
Hi everyone;
I'm doing a project which involved jet impingement on a flat surface for cooling
I'm using Ansys Fluent 13.
My Reynold number is about 46000
(8 mm nozzle diameter and 54 m/s jet velocity)
H/D =4
I'm using K-w SST or K-epsilon turbulance model.
Plate thickness is 4 mm
i used coarse meshing to be sure that im at the right way(after that i'm going to make fine meshing) but i can't see the temperature distrubution right to go on.After 45 seconds with transient process the centre of plate's temperature is high and the corners are lower. But the velocity vectors seem fine.
Please help me . This situation has driven me crazy for about one week.
(i only want to investigate heat transfer from plate. So do i have to model nozzle? is it necessary? )
Overdosed is offline   Reply With Quote
Old   March 17, 2013, 08:46
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
Can you elaborate your problem a bit more like boundary condtions and inflow parameters.
Did you specify the temperature boundary condition on the plate wall.
taxalian is offline   Reply With Quote
Impinging Air Jet Cooling on Flat Plate(Please Help) :( Overdosed FLUENT 1 June 8, 2013 19:59
DNS for Impinging Jet on a Flat Plate Chandra Shekhar Main CFD Forum 3 January 18, 2010 06:03
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
air jet impingment on a moving flat plate blueman_esf62 FLUENT 0 May 2, 2009 03:40
air jet impingment on a moving flat plate blueman_esf62 FLUENT 1 April 27, 2009 10:40
