2d CGNS grid for use with ensight
Old   May 16, 2006, 22:37
Default 2d CGNS grid for use with ensight
zonexo
hi,
i've generated a 2d structured c-grid airfoil with solution (velocity,pressure) using CGNS. reading with tecplot is ok. however, when i tried to use with ensight, there are some problems.
1. my grid is 157x39. under the import option, it was shown that my grid is 156x39x156. if i load everything, the c-grid will be shown, but with lots of diagonal lines.
2. if i load it as 156x39x1, the grid will be shown correctly
3. however, in both cases, the velocity and pressure are all zero, although their values have been entered.
the fix is to create a 3d grid with the k dimension = 1 ie grid of 156x39x2. the pressure and velocity will be shown correctly too.
but is this problem due to ensight or cgns or error on my part? creating a 3d grid will waste space and i'll also need to do additional conversion.
Hope someone can help. thanks
write unstructured grid on cgns manaliac Main CFD Forum 0 June 1, 2010 04:52
Tetra grid generator for CGNS Jenna Main CFD Forum 0 March 27, 2005 10:57
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 09:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 17:43
