solving a differential equation with NEWTON....
Old   May 15, 2006, 03:05
Default solving a differential equation with NEWTON....
myway
I want to solve a differential equation y'=B*y-A*C*exp(B*x)*sin(C*x) using Euler (implicit) and a Newton-like method.
But let me give you a short introduction into my problem.
Euler (implicit) is defined as: u_i+1 = u_i + du/dx_i+1 * Dx
Since not all terms on the right hand side are known, a (system of equations) must be solved, which is:
F(u_i+1) = u_i - (u_i+1 + Dx * (B*u_i+1 - A*C*exp(B*(x+Dx))*sin(C*(x+Dx))))
Some people told me, I could solve the problem with the Newton-procedure. The principle is clear to me. But can anybody tell me how I have to calculate u*, which is the value of u where the tangent intercepts the x-axis??? I need that value to calculate the next tangent.
Thanks for your patience.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
