richardson extrapolation
Like Tree1Likes
Old   March 11, 2013, 16:31
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Either you hava a look at Ferzigers book (not freely available online as far as I know) or you can derive the formula yourself.
Use the Ansatz F(h_i) = F(h=0) + a*(h_i)^p
(where h_i is the grid spacing, f(h_i) is the value obtained on this grid, F(h=0) is the solution without discretization error, a is a constant and p is the error order.
With solutions on three different grids with the same refinement ratio r (r= h_2/h_1 = h_3/h_2) you get 3 equations.
(I) F(h_1) = F(h=0) + a*(h_1)^p
(II) F(h_2) = F(h=0) + a*(h_2)^p
(III) F(h_3) = F(h=0) + a*(h_3)^p
(I')=(I)-(II) F(h_1)-F(h_2)= a*[(h_1)^p-(h_2)^p]
(II')=(I)-(III) F(h_1)-F(h_3)= a*[(h_1)^p-(h_3)^p]
(I'')=(I')/(II') [F(h_1)-F(h_2)]/[F(h_1)-F(h_3)]=[(h_1)^p-(h_2)^p]/[(h_1)^p-(h_3)^p]
now using the definition of r, the right hand side becomes (1-r^p)/(1-r^2p)=1/(1+r^p)
after some more algebra we arrive at
p=log[F(h_1)-F(h_3)]/[F(h_1)-F(h_2)-1]/log(r)
flotus1 is offline   Reply With Quote
Old   March 12, 2013, 11:30
Albert Puig
Puigar is on a distinguished road
Hi folks again
first of all, thanks for the responses! ther were really useful to get a plain understanding of what is the richardson extrapolation and how to apply it to my problem.
I have another doubt. If I only have the values of f(h20),f(30) and f(40) because the coarsened grid (f10) does not work, can I manage to get the order of error "p"?
for example. in some case I can run all teh simulations with all of the grid, including the coarsened. But there are some conditions that when I apply them to the model, they make it more unstable, to the point that the coarsened grid (f10) falls off.
for example
case 1
all of them work: I get p and F for richardson extrapolated value
x y
h -> F_h
h/2-> F_h/2
h/4-> F_h/4
case 2
Can I use the value "p" for richardson extrapolated value of CASE 1 if the trends of the two results of F and G are more or less the same? how can I assess the similarity of the trends of F and G to validate the value of the order of the error "p"?
x y
(h doesn't work)
h/2-> G_h/2
h/4-> G_h/4
thank you again for paying attention! It has been a great favour
Puigar is offline   Reply With Quote
Old   March 12, 2013, 11:49
flotus1's Avatar
Alex
With solutions on only two different grids, there is no way in estimating the error order.
Even worse, if the convergence is not monotonic and you just guess a value for p, you end up with a completely wrong extrapolated value.
So 3 solutions (with three different element sizes) are always necessary.
If you did not refine with the same ratio, you can still try to solve [F(h_1)-F(h_2)]/[F(h_1)-F(h_3)]=[(h_1)^p-(h_2)^p]/[(h_1)^p-(h_3)^p]
some way.
The easier way is to keep the same ratio in both refinements.
Take the coarsest mesh on which you get a reasonable result as a starting point.
Now the finer mesh doesnt have to be h/2 if the solution at h/4 becomes too expensive.
A refinement factor of e.g. 1.5 is still enough to do a reasonable extrapolation in most cases.
Old   March 12, 2013, 12:07
Albert Puig
some way.
so I can get a p value from taking for example h/2 h/3 and h/4? even if they are not doubled? Just I have to apply the ansatz formula again with these refinements to get "p"?
Old   March 12, 2013, 12:32
flotus1's Avatar
Alex
The thing is that you connot solve for p explicitly if the refinement ratios are not identical.
So h/2, h/3 and h/4 is not a good choice.
And yes, the meshes dont need to be refined with a factor of 2 (or 0.5 in the definition I used above)
Any factor far enough from 1 will do.
Old   March 13, 2013, 10:06
Albert Puig
So then? If it is not explicitly done, how can I solve it?
I did not get how was this step done when getting the three equation solving of "p"
Old   March 13, 2013, 10:53
flotus1's Avatar
Alex
1-r^{2p} = 1^{2}-(r^{p})^{2} = (1-r^{p})(1+r^{p})
Old   March 13, 2013, 11:44
Albert Puig
Sorry for being sooo lame..
I just don't get how you are introducing r here.
Old   March 13, 2013, 13:18
flotus1's Avatar
Alex
r is the ratio of the element sizes and was introduced a few posts ago.
r= \frac{h_2}{h_1}=\frac{h_3}{h_2}
Richardson extrapolation pc Main CFD Forum 11 March 8, 2013 07:50
Discretization error with Richardson extrapolation. cfdstudent004 CFX 1 May 29, 2012 20:04
Richardson Extrapolation to check time and space convergence Hooman Main CFD Forum 0 December 29, 2010 09:19
Richardson extrapolation cynthia FLUENT 4 June 20, 2008 09:58
One-sided extrapolation coolblizz Main CFD Forum 2 February 8, 2006 21:24
