Strategy for a projectile moving inside a tube
Old   March 7, 2013, 15:49
Default Strategy for a projectile moving inside a tube
kiwa21 is on a distinguished road
Hello everyone,
I am a new user of ANSYS / Fluent, and I need to model a projectile moving trough a tube for my research internship and I have no idea of how I can start..
The problem : Let the diameter of my projectile be Do, initialy it is in a tube of the same diameter Do and it's moving into another tube of diameter 2Do (with supersonic speed M=4 for example). These 2 tubes are separeted by a "magical" interface which breaks only when the projectile "shatters" it. The goal is to study the transient region at the entrance of the second tube !
I can work with the assumptions :inviscid fluid, axisymetric flow, ideal gas (non reactant mixture)
Can you give me some advice of what should I start reading / doing, which tutorial can I do, which steps I'm supposed to do, what I need to mesh etc...
I've read that I probably need to understand how to do : Dynamic Mesh, 6DOF, UDF but I can't find a lot of information on these subjects ...
I'm not asking that somebody does the job for me, at this point I only need some advice, example files or good tutorial
Thank you very much !
kiwa21 is offline   Reply With Quote
dynamic mesh, fluent, projectile, transient
[ANSYS Meshing] Meshing Strategy for inside geometry powpow ANSYS Meshing & Geometry 6 January 16, 2013 05:32
How do I set a boundary at a hole inside the tube Theerawat FLUENT 4 July 16, 2012 08:07
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
Tube inside a tube simulation Rashmichem Main CFD Forum 0 December 14, 2010 02:52
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
