Valve seal problem! Urgent
Old   May 11, 2006, 23:04
Default Valve seal problem! Urgent
songxguan
Hello, everyone. I'm doing reseach about the rubber seal between a valve disc and valve body. Most company use rubber compressed in them. but how much should the "compress pressure" be? As u know, if the pressure is too little, the fluid (water) will leak; otherwise, the "wear" will be greater.
Is there a prediction or empirical equation about the relation between "seal compressed pressure" and the "hydaulic pressure", which the rubber seal ring can resist.
It's very urgent, does anyone know? please, help!
technical problem when inputting --- urgent kangyun Main CFD Forum 2 November 4, 2010 06:55
urgent problem in the multi-stage multi-row computation BalanceChen Fidelity CFD 2 September 23, 2010 22:26
Multiphase Problem (Urgent) Dadang CFX 4 June 21, 2004 08:46
Urgent help on Sand casting problem arunprasad FLUENT 0 April 18, 2004 06:04
An urgent problem, HELP!!! Fanadam FLUENT 1 May 3, 2003 00:38
