Turbulent channel flow by LES
Old   May 11, 2006, 01:51
Default Turbulent channel flow by LES
Paul
I am testing LES turbulent models by simulating the standard channel flow. But unfortunately, I cannot get to the turblence even after a very long period of computating time. The Reynolds number is 3000, defined by the averaged streamwise velocity and channel half width. Can I ask for any suggestions about it?
Old   May 11, 2006, 03:47
Default Re: Turbulent channel flow by LES
tom
The initial velocity field should have sufficiently large disturbances, fluctuations 10% of the mean, say, and not only random noise but also disturbances with a longer wave length. I just take some random cosine waves.
Old   May 11, 2006, 04:07
Paul
Thank you, Tom.
Can I have the expressions for the disturbance, or any papers about disturbances?
Do your random cosine waves mean that their amplitude and phase angle are random?
Old   May 11, 2006, 05:43
siri
Short wave disturbances (random noise) tend to die fast. As tom said, try also with cosine or sine waves (with wavelength of the order of the channel height). Besides, depending on which SGS model you are using, the Re number may be too low to mantain turbulence. I would try with higher Re numbers first.
Old   May 11, 2006, 05:56
Paul
Thank you siri.
I am testing Smagorinsky model and standard dynamic model. Are these wave disturbances only for initial flow field?
Old   May 11, 2006, 06:05
Paul
Sorry, Tom mentioned already that the disturbances were for initial field.
Old   May 11, 2006, 11:48
agg
Try this IC
u(x,y,z) = C(1-y^8) + E*2*pi*sin(pi*y)*cos(x)*sin(z) v(x,y,z) = -E*(1+cos(pi*y))*sin(x)*sin(z) w(x,y,z) = -E*pi*sin(x)*sin(pi*y)*cos(z)
C is the centerline velocity and E=0.1*C
Old   May 12, 2006, 03:01
diaw (Des_Aubery)
Agg wrote:
Try this IC
diaw:
Nice standing wave-forms. Wonder what you'll see if you altered the mode numbers a little, or set them moving?
diaw... (Des Aubery)
Old   May 12, 2006, 03:12
Default Re: Turbulent channel flow by LES *NM*
diaw (Des_Aubery)
Old   May 12, 2006, 03:19
Paul
Thank you, agg!
I guess y is in wall normal direction. Am I right?
Old   May 12, 2006, 03:26
Default Turbulent channel flow by LES (one more question)
  #11
Paul
May I ask the order of the spanwise velocity in this turbulent channel flow? (comparing to mean streamwise velocity)
Old   May 12, 2006, 04:37
Default Re: Turbulent channel flow by LES (one more questi
  #12
diaw (Des_Aubery)
Paul,
Judging from the form of agg's I/C, there is only an initial standing waveform in the y- & z- directions. The x-velocity is given an initial velocity component, the rest is a standing waveform.
diaw...
Old   May 13, 2006, 19:09
  #13
agg
I'm sorry i forgot to mention the reference. I don't want to take credit for the IC
"Large Eddy simulation of channel flow using finite-difference techniques" D.K. Tafti and S.P. Vanka Report No. CFD-1, Dept. of Mechanical and Industrial Engr. UIUC, March 1990
You could change the value of E to change the fluctuation levels. The paper states "The initial divergence free field satisfies the boundary conditions and consists of a 3D disturbance (wavenumber unity) superimposed on a 2D mean flow."
And yes Y is the wall normal direction
I have an e-paper (pdf version) that gives IC based on Tollmienn Schlichting (TS) waves. If you need it just ask and i will email it to you.
Old   May 14, 2006, 00:08
  #14
diaw
agg: I have an e-paper (pdf version) that gives IC based on Tollmienn Schlichting (TS) waves. If you need it just ask and i will email it to you.
diaw:
I would be very grateful if you could e-mail the paper to <des@adtherm.com> . Thanks very much.
diaw...
Old   July 6, 2009, 05:02
Li.cy
dryhill is on a distinguished road
i can't find this paper , what is size of the domain? i guess 2pi*2*pi ,right?
only this size can eliminate jump at periodical boundary in x and z direction
can i adjust the wave number?
Originally Posted by agg
;42615
dryhill is offline   Reply With Quote
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 17:26
turbulent developed lenght in oppen channel flow zandi Main CFD Forum 0 January 9, 2010 15:52
Initial conditionfor turbulent channel flow in LES pankaj saha Main CFD Forum 0 November 30, 2007 13:04
Turbulent channel flow roberthino OpenFOAM Running, Solving & CFD 5 August 15, 2007 09:35
Pressure drop across a turbulent channel flow shiv Main CFD Forum 0 September 21, 2005 01:52
