Diagonal storage for c-grid airfoil possible?
Old   May 10, 2006, 11:13
Default Diagonal storage for c-grid airfoil possible?
zonexo
hi,
i'm trying to solve the sys of linear eqns due to flow past a c-grid airfoil. due to the structure of c-grid, it is folded such that it touches itself, resulting in coordinate cut.
becuase of this, it is not possible to use the diagonal storage for the "A" matrix. Besides increase in memory, iteration is also slower when using other forms of matrix storage such as compressed sparse row.
is there any way (reorder, ghost cell etc) which can be done to enable the use of diagonal storage? any hints will be welcomed.
tks!
Old   May 10, 2006, 14:43
Default Re: Diagonal storage for c-grid airfoil possible?
Bounecer
I've written a fortran code program to study 2D, incompressible viscous flow about airfoil, i've used structured C-grid generation and discretized the flow equations in numerical domain with finite volume method. I've introduced SIMPLER algorithm and used second order UPWIND scheem for convective terms. I've obtained a pentadiagonal system, with sweeping and TDMA (tridiagonal matrix algorithm) i've solved the system. My program run with verry small relaxation parameters (5*10**-2), but when the difference between two consecutive values of velocity is (10**-4) it diverges
Airfoil Grid Generation morteza08 Main CFD Forum 6 February 28, 2012 14:13
Grid generation of an airfoil in Ansys workbench 12.1 sunish5 ANSYS 1 October 27, 2010 00:29
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
how iam determine good quality of mesh grid of airfoil using gambit nuimlabib FLUENT 2 June 29, 2009 09:11
MapFields to New Grid For Extreme Grid Deformations due to Body Motion albcem OpenFOAM 0 May 5, 2009 15:17
