SIMPLE and spurious oscillations
Old   May 5, 2006, 18:20
Default SIMPLE and spurious oscillations
Max
Hi!
I am carrying out the computation of a swirling combustion chamber:
1- 3D, (nearly) isotropic unstructured grid
2- SIMPLE, stationary version (no time-dependent terms)
3- k-epsilon turbulence model
4- energy and species equations
The problem is that I can get a "stationary" solution only if I use a first-order upwind scheme for the convective terms. Higher order schemes (CDS, QUICK, LUDS, ecc...) do not yield to a stationary solution even with a limiter function. On the other hand, the cold run (no chemical reactions, no flame, only small T gradients due to high wall temperature) converges with all these schemes.
Moreover: I have tried to perform some iterations keeping all the variables but velocity and pressure constant (under relaxation factor = 0) and even in this case V and p oscillate without end.
Very generic question: what can I do to improve the situation?
Thanks Max
Old   May 5, 2006, 22:27
Default Re: SIMPLE and spurious oscillations
diaw
Do you expect the flow to be steady? Are you sure that a 'stationary' solution exists? Turn off all convection stabilisation & see what happens. Plot the output data at various times (say a cutplane), put into Powerpoint & run as a movie. What do you observe? Are there any patterns to what you see?
diaw...
Spurious currents using interFoam (OF 1.6) peterW OpenFOAM 2 October 5, 2009 19:39
