Turbulence modelling - 2d dump combustor
Old   April 25, 2006, 13:43
Default Turbulence modelling - 2d dump combustor
pXYZ
I would like to know your oppinion.
I am investigating a 2D dump combustor. (It is a very easy geometry. The fluid enters a channel at left side. After a few centimeters the flow has to cope with a sudden channel-expansion, which was realized as a chair). My investigations are steady and I want to test several turbulence modells. Because of the bad aerodynamic conture the creation of a shear flow is assumable!
1. Using a standard k-eps-modell, what would you expect for the quantities k and eps in this environment? Since k is addicted to u'v' it should rise to maximum in the shear flow (that's my opinion.)
2. Where would you expect eps (dissipation rate or destruction) to reach its maximum?
3. Finally, I would be very pleased if you could refer me to any good literature, so I can validate my investigations.
thanks a lot.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulence modelling - 2d dump combustor pXYZ Main CFD Forum 0 April 25, 2006 13:43
Turbulence modelling Panos Siemens 6 July 8, 2004 03:40
