February 8, 2013, 18:36 |
How to implement Robin Boundary Conditions?
Rep Power: 13 |
Hi, I'm currently working with a code that requires to assign the Boundary conditions using the coefficients on the general form of Robin Bc (a*u + b * du/dn = g)
From my understanding I can assign Dirichlet conditions by setting a=1, b=0, and g the desired specified value. Similarly for Neuman bc I need to set a=0, b=1, and g the desired value. is this correct so far? Now lets considered a quadrilateral element 1--------2 | | | | 3--------4 where there is Neuman boundary defined over the element and dirichlet on the nodes 1 and 3 Since I'm doing groundwater modeling, lets say I have specified hydraulic head for nodes 1 and 3 H=10 m and recharge flux equal to 1e-4 m/day. Lets say that the area of the element is 1e6, then 100 m^3/day are coming into that element. Using FE discretization the flux will split into 25 m^2/day per node. I assume that for the nodes 2 and 4 the coefficients have to be a=0, b=1, g=25. But what are the values for the nodes 1 and 3? Thank you George |
February 9, 2013, 04:52 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Assume the point 3 is at x=y=0 coordinates. Assume a bi-linear approximation on 1-2-3-4: u(x,y) = c0 + c1*x +c2*y +c3*xy that over the boundary x=0 leads to du/dx = c1+c3*y Hence, your Robin Bc along edge 3-1 becomes a*(c2*y) + b*(c1+c3*y)= g where a,b, g must be known from your problem. |
June 12, 2017, 11:40 |
How to implement Robin Boundary Conditions in groovy?
Sachin
Rep Power: 10 |
I also would like to implement robin boundary condition in my electrostatic program. To implement my robin BC in code, I am comparing my problem with heat exchange robin BC. Final robin BC in heat exchange problem is Tface = f*Tinf + (1-f)* Tcentre ; f=(1+(k/alpha*delta)) So my question is how to find fraction value (f) in robin BC? My robin BC is (E*Np)-(grad*Np)=0 Here E is surfaceScalarField ; Np is volScalarField(both scalar value I am calculate). So can anyone help me to find out fraction value for robin boundary condition and how to implement in groovy? Thanks |
boundary condition, finite element method, robin conditions |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 08:21 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 18:15 |
hexagonal boundary conditions | s_h | Main CFD Forum | 0 | August 9, 2009 23:15 |
Help with boundary conditions | Dan | CFX | 0 | April 3, 2006 12:32 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 19:29 |
