implicit vs explicit
Old   April 21, 2006, 06:59
Default implicit vs explicit
pXYZ
I have written a little program to solve an ordinary dfferential equation. The user can decide whether an explicit or implicit integration method is used. Looking on the results, I cannot see any advantage of the implicit scheme.
What do you think about it?
The mathematical bakground was:
IMPLICIT: f(t+Dt) = f(t) + Dt* df/dt|_(t+Dt)
EXPLICIT: f(t+Dt) = f(t) + Dt* df/dt|_(t)
Old   April 21, 2006, 08:15
Default Re: implicit vs explicit
Tom
Try using f(t+Dt) = f(t) + 0.5*Dt*( df/dt|_(t+Dt) + df/dt|_(t) )
and vary the timestep comparing the results.
For an ode you'd should really look at explicit Runge-Kutta methods rather than your forward Euler step.
Old   April 21, 2006, 10:48
Steve
One way of looking at it is that if f(t) is mass say and therefore df/dt is mass flow, what happens if Dt*df/dt(t) is negative and higher in magnitude than f(t)?
In the explicit scheme you'll get negative mass (bad!). In the implicit scheme the iterated estimate of df/dt(t+Dt) will prevent the negative mass.
Explicit schemes assume that the grients at (t) are constant through the step. Implicit ones don't. Explicit schemes require small steps because of this.
Implicit versus Explicit Deepak Main CFD Forum 17 November 7, 2015 14:14
Implicit or explicit ? Rickard.Solsjo OpenFOAM 0 May 31, 2011 05:02
ddt explicit or implicit with courant number!! mrshb4 OpenFOAM 0 December 13, 2010 12:13
From Explicit to Implicit formulation emanuele FLUENT 2 October 4, 2006 15:17
Euler (explicit or implicit) anybody Main CFD Forum 2 May 8, 2006 03:12
