Cavitation: implementation of Schnerr-Sauer model
Old   January 30, 2013, 17:06
Default Cavitation: implementation of Schnerr-Sauer model
luftraudi is on a distinguished road
I'm working on the implementation of the Schnerr-Sauer cavitation model in our cfd code, but I had some problems with the correct implementation of the source term in the transport equation. My problems are as follows:
If I initialize my flow field with pure liquid, so the volume fraction of the vapour is zero leading to a vanishing source term (in cavitating regions where the pressure is below the vapour pressure) since the radius R become zero. Thus no cavitation occur. This is quite physical behavior since cavitation is linked to the presence of nuclei.
If I initialize my flow field with nuclei (e.g. vapour volume fraction value of 1.e-5) cavitation can occur in regions where the pressure is below the vapour pressure. Now the problem is, that the condensation source term (in regions where the pressure is above the vapour pressure) is non-vanishing leading to a reduction of the vapour volume fraction. In the worst case the vapour volume fraction become negative, which is not physical.
does anyone has experience with this topic? If so, how did you come up with this aspect? Did you implement a source term which is different from what is presented in your papers or did you modify the numerical procedure (finite volume, Euler implicit, upwind interpolation) for the transport equation for the volume fraction in order to keep the volume fraction between the physical bounds 0 and 1?
With regards,
luftraudi
luftraudi is offline   Reply With Quote
Old   November 21, 2013, 23:52
Rohith
RaghavendraRohith is on a distinguished road
Hi Michel
In ANSYS Fluent, as i worked in that the source term enhances phase change from fluid to vapor and vapor to fluid. The additional source term is greater and smaller than the vapour pressure depending on the pressure linked equations.
Please check it in my work.
Thanks
Rohith
RaghavendraRohith is offline   Reply With Quote
cavkt
cavitation model pressure distribution Rahmat Arazgaldy FLUENT 1 May 16, 2012 16:48
UDF for linear PTT model implementation dpitz Fluent UDF and Scheme Programming 1 February 4, 2011 11:08
MODEL FOR CAVITATION kostas FLUENT 0 December 27, 2008 18:11
FLUENT cavitation model CFDtoy FLUENT 4 October 15, 2008 11:31
A reference on implementation of Spalart-Alam. Turbulence Model? Mohammad Kermani Main CFD Forum 2 December 26, 1999 03:56
