Dynamic pressure and Lift coefficient
Old   January 30, 2013, 11:46
Exclamation Dynamic pressure and Lift coefficient
shajin majeed
shajinmajeed is on a distinguished road
While doing an analysis in delta wing i came across a difficult result. the values i got for two different analysis made me confused. in the first one the dynamic pressure was less compared to the second one, but when it comes to the part of lift,drag and its coefficients the ironic thing happened.For the one which i got the most dynamic pressure shows the less lift,drag and coefficient of lift and drag while the other one has high values on those parameters. the test conditions as follows
Velocity-0.3 mach
gauge pressure-0 pa
angle of attack- 0
Thanks in advance if the problem is solved.
shajinmajeed is offline   Reply With Quote
coefficient drag, coefficient of lift, drag, dynamic pressure, lift
Can vorticity or pressure coefficient plots be used to explain the thrust and lift? quarkz Main CFD Forum 2 March 8, 2016 16:03
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 07:07
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
