hydro turbine 100 kw
Old   April 17, 2006, 00:41
Default hydro turbine 100 kw
owen smith
i have 30 metre wide river with approx 300-500mm deep of water at its lowest point summer time,but with almost no head .my question is would i be able to harness enough water to run a 100 kilowatt alternator or turbine. thanks for all your input.tum
Old   April 17, 2006, 05:45
Default Re: hydro turbine 100 kw
Kasyap
Dear Smith,
For this particular application u can look for low head turbines like Kaplan turbine, bulb turbine etc(axial flow machines).But the discharge for those will be high.If u know the average velocity of river u can find whether it is possible to generate 100kw.u need to know the head even though it is so small,to calculate poer available
Old   April 22, 2006, 22:51
owen smith
the head would be aproxamatly 1-1.5m with a river valocity of around 1metre a second i do not wish to use batterys thanks
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 04:02
formatted point data- icem HSK CFX 12 August 11, 2011 22:25
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 01:14
CFD Expert for Hydro Turbine Runner profiles hydroelectricpro Main CFD Forum 2 February 17, 2010 02:17
Help! How to find efficiency of hydro turbine? Sanjay Jain FLUENT 0 May 9, 2008 13:09
