Solution diverging on using double precision
Old   January 22, 2013, 04:11
Default Solution diverging on using double precision
qrie is on a distinguished road
I have an incompressible Navier Stokes code that was working fine as long as I was using single precision. When I converted to double precision, the residues are very high. Why is this happening?
Thanks!
Qrie
qrie is offline   Reply With Quote
Old   January 22, 2013, 12:29
Martin Hegedus
Martin Hegedus is on a distinguished road
A bug in your code?
Sometimes issues like the following may occur
if (xx == 0.0) {
then do something
Under single precision this might work but double does not if xx is very small but not equal to 0.0, for example xx=1.0e-12. Single precision would round value to zero. Error tolerances should be used.
if (abs(xx) < 1.0e-8) {
then do something
Martin Hegedus is offline   Reply With Quote
Old   January 23, 2013, 00:11
That helps! Thank you!
divergence, double precision
Parallel rasInterFoam openfoam_user OpenFOAM Running, Solving & CFD 4 November 1, 2008 05:14
When to use double precision Mark Render Main CFD Forum 10 January 21, 2008 13:16
re: Double precision and grid quality Wooster CFX 5 July 26, 2007 11:10
UDF & Double precision; Please help?? Asghari FLUENT 0 January 31, 2007 14:14
HELP! Diverging Solution for Incompressible Prob. Bob FLUENT 3 April 16, 2006 20:33
