Using compressible BCs for incompressible problems
Old   April 9, 2006, 02:07
Default Using compressible BCs for incompressible problems
cfd
Hello ppl,
I'm trying to formulate the flow past a block in an open domain. I've a fractional step scheme on hand and I'm using the finite volume method. I've used it to test Ghia's lid driven cavity and results are very similar.
I believe I just need to modify the boundary conditions (BCs) for my new problem. I was reading Blazark's CFD book and these are the BCs given for subsonic inflow and outflow (mine is an incompressible problem)
For inflow a belongs to outside of domain, b is on the boundary, d is inside domain. a .... b .... d
p(b)=0.5*{p(a)+p(d)-rho(0)*c(0)*[nx*(u(a)-u(d))+ny*(v(a)-v(d))]}
rho(b)=rho(a)+(rho(b)-rho(a))/c(0)^2
u(b)=u(a)nx*(p(a)-p(b))/(rho(0)*c(0))
v(b)=v(a)nx*(p(a)-p(b))/(rho(0)*c(0))
rho(0) & c(0) represents reference state
For outflow a belongs to outside of domain, b is on the boundary, d is inside domain. d .... b .... a
p(b)=p(a)
rho(b)=rho(d)+(rho(b)-rho(d))/c(0)^2
u(b)=u(d)nx*(p(d)-p(b))/(rho(0)*c(0))
v(b)=v(d)nx*(p(d)-p(b))/(rho(0)*c(0))
p(a)=prescribed static pressure
So, is this BCs applicable since this is an incompressible problem?
Also in most problems, ppl usually specify inlet velocity (e.g. u=1,v=0). Is there a need to specify pressure at
inlet as well?
Old   April 16, 2006, 03:41
Default Re: Using compressible BCs for incompressible prob
Harish
When you specify velocity you do not usually specify pressure.Have a look at peric and ferziger for more details.
-H
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 11:47
Blow of compressible solver while using K-epsilon model in openfoam Amit Mathur OpenFOAM 16 October 6, 2013 12:09
Fixed grid methods for compressible viscous flow liujmljm Main CFD Forum 1 November 7, 2010 18:54
p & U outlet bcs for realistic wind inlet profile stevek OpenFOAM 4 July 19, 2010 03:29
Problems with convergence and initial guessed fields in compressible steady flows Pedro Gil Main CFD Forum 3 April 25, 2000 12:34
