k - omega SST turbulence model with wall functions
Old   January 17, 2013, 07:14
Default k - omega SST turbulence model with wall functions
kenan is on a distinguished road
Hello to all,
Recently I have been reading a lot about Menter's k-omega SST turbulence model to be able to get more conscious with its usage. I found out that it has very well improved formulations for near-wall flows, when grid resolution is adequate in this region. However i couldn't get to understand the following issues:
- Does this model still have improved skills over the k-epsilon model, when i have a coarse near-wall mesh?
- Menter's k-omega model is said to switch between k-epsilon and k-omega, in free-stream region and near-wall region, respectively. So, if i have for example a y+>30 mesh near-wall, does this switching take place? If it does, how? Because i think wall functions already handle closest cells near wall.
- I guess the SST formulation isn't activated in coarse near-wall meshes, is it true?
Thanks in advance.
Kenan
kenan is offline   Reply With Quote
k-omega sst model
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 14:57
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
k-omega SST cylinder with no wall Functions owayz OpenFOAM Running, Solving & CFD 10 July 31, 2012 17:57
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 06:15
3-D turbulence model with wall function Henry Main CFD Forum 7 May 19, 2006 11:40
