January 10, 2013, 07:53 |
Mean Strain rate
Michael Rembe
Rep Power: 16 |
I'm not an expert in fluid mechanics. In the SMAGORINSKY-model I need the square root of Sij*Sij. I'm a little confused about the different notations. What is the defference between the mean strain rate defined as: and the mean strain rate defined as: Sij=0.5*(dUi/dxj+dUj/dxi) Some times I can read: S=sqrt((dUi/dxj)^2+(dUj/dxi)^2) I would be very grateful for a short explanation. Thank you very much! Michael |
January 14, 2013, 03:11 |
Rami Ben-Zvi
Rep Power: 17 |
Hi Michael,
That's simply tensor algebra (using the sum convention). If you use the definition Sij=0.5*(dUi/dxj+dUj/dxi) , substitute it in s^2 =Sij*Sij and sum over i and j, you'l get the result from the other expression, S=sqrt((dUi/dxj)^2+(dUj/dxi)^2) you get S^2=Ui,jUi,j+ Uj,iUj,i = 4SijSij - 2Ui,jUj,i so it is different due to the last term. |
strain rate in UDF | Paulina | FLUENT | 11 | November 20, 2014 03:06 |
Shear Strain Rate | Dave442 | Main CFD Forum | 5 | October 25, 2013 04:08 |
strain rate magnitude | ahmadbakri | STAR-CCM+ | 1 | June 3, 2010 13:03 |
Strain rate. | MM? | Main CFD Forum | 1 | February 15, 2006 08:55 |
strain rate at arbitrary position in a cell | K. Kevala | FLUENT | 0 | February 4, 2004 17:14 |
