Determine the exact location of the vertex center?
Old   April 3, 2006, 18:02
Default Determine the exact location of the vertex center?
Anna
Hello, everyone,
I am asking a question about data postprocessing. I get the results for the flow past a cyliner. But I don't know how to exactly locate the center of the vortex behind the cylinder and how to exactly get the separation angle.
You help is most appreciated!
Thanks a lots!!!
Old   April 4, 2006, 03:36
Default Re: Determine the exact location of the vertex cen
ganesh
Dear Anna,
I am not sure if the 'exact' location of votex center and the separation angle can be determined. However, from viewpoint of data processing, a reasonably good ide of these can be obtained. These can be obtained by plotting the streamlines for the flow.
Hope this helps.
Regards,
Ganesh
Old   April 4, 2006, 05:08
ramp
Hi !!
You can find the center of vortex from the stream-function data and recirculation (or wake) length from the velocity data.
Separation angle: Separation angle can be determined by calculating the vorticity (or shear-stress) on the surface of the cylinder. The point at which the value is zero can be noted as the point of separation (or separation angle).
Best regards.... Ramp
Old   April 4, 2006, 12:04
Default Thank you! Ganesh and Ramp
Anna
Lots of thanks for your help. I will try to figure it out.
You are very helpful!!
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
