Mesh coarsening
Old   April 1, 2006, 09:42
Default Mesh coarsening
Luca
May anybody suggest me a library for mesh coarsening? I need to coarse my grid during the simulation (like a multigrid) Luca
Old   April 2, 2006, 11:48
Default Re: Mesh coarsening
Renato.
try this one http://tetra.mech.ubc.ca/GRUMMP/
Old   April 2, 2006, 17:39
Luca
Thanks Renato. It seems GRUMMP is the only library available on the net. I have some problems in compiling with gcc 4...but I'm trying to use it. Is this the only one you know? Luca
Old   April 2, 2006, 19:01
Renato.
I must admit that I haven't got success with GRUMMP too...
You're right regarding the lack of coarsening libraries available. I have already tried to find Googling around but I only found GRUMMP, Pyramid and MGridGen.
Pyramid is available at OpenFoundation site ( http://www.openchannelfoundation.org/projects/Pyramid ) it's written in Fortran90 and work with ParMetis in parallel doing AMR
MGridGen and ParMGridGen ( http://www-users.cs.umn.edu/~moulitsa/software.html ) are softwares of the same group that released Metis and ParMetis. It was a product of Irene Moulitsas research in her PhD but the software only works with CSR graph structures.
I work with 3D/FEM/linear-tetrahedra and I haven't found a library free, easy to use and install for doing mesh coarsing for my case. If you find any library that fits these features, please post a message here because I'm in the same boat than you ;-)
Regards
Renato.
Old   April 3, 2006, 04:40
Fluentuser
Dear Renato, unfortunately GRUMMP still gives me a lot of errors...It 's the only library to coarse a grid into usable tetrahedra. Pargridgen by Irene would be great but it just a tool for grid agglomeration (for multigrid purposes). Instead, I 'd like to reduce the number of cells (GRUMMP does exaclty what I want...) If anybody using GRUMMP could help me maybe I'd not give up with GRUMMP. Thanks a loto Renato Luca
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 14:40
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
