Propeller as BC
Old   March 30, 2006, 07:15
Default Propeller as BC
Chris
Hi guys,
I want to calculate the flow around a fuselage of a motorglider and want to set the the Inelt_BC into the propeller-plane. To set the BC properly, I need the turbulence intensity, turbulent lenght scale a.s.o direclty downstream of the prop. Unfortunatly, I didnīt find any infos on the internet - itīs all about propeller performance, but nothing about aerodynamics. Can anyone recommend homepage, papers or books?
Thx, Chris
Old   March 30, 2006, 07:22
Default Re: Propeller as BC
Jim
The ESDU sheets are pretty good for propeller stuff (www.esdu.com), problem is you'll need to subscribe. If you're at Uni, or have a mate with an Athens account, you should be able to get in that way.
Old   March 30, 2006, 12:41
A.S.
I have whole multi-block code for such analysis, if you wish.
Propeller calculation toil CFX 15 May 22, 2017 05:06
Modelling an accelerating propeller siw CFX 2 September 21, 2011 10:53
Modelling a propeller tomg STAR-CCM+ 4 April 28, 2011 18:22
Propeller torque Alex H FLUENT 1 November 1, 2006 07:18
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 09:23
