algebraic multigrid vs geometric multigrid
Old   December 30, 2012, 16:01
Question algebraic multigrid vs geometric multigrid
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
What is the advantages and disadvantages of Algebraic Multigrid compared with Geometric Multigrid? From my experience, algebraic multigrid is much slower than geometric multigrid. Is that always true? Why?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   January 2, 2013, 07:43
ignatius is on a distinguished road
Hi Anna,
Algebraic multigrid is supposed to work better with complex geometries and also with highly anisotropic problems. It would be nice if you can get somewhere the book "Multigrid" from Trottemberg, there you can find a really good explanation about it, it has an appendix about algebraic multigrid.
ignatius is offline   Reply With Quote
Old   June 13, 2013, 12:55
Question
Anna Tian's Avatar
Meimei Wang
Originally Posted by ignatius View Post
Hi Anna,
Could you give a basic conclusion about what are the advantages of geometric multigrid method compared with algebraic multigrid method? Is it always faster?
Best regards,
Meimei
Old   June 17, 2013, 23:28
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
To clarify, geometric multigrid actually discretizes the problem on a series of grids whereas algebraic multigrid simply works with the linear system. When working with unstructured grids it is really difficult to define a series of meshes for geometric multigrid so algebraic multigrid is usually used instead. It's not really a matter of speed, more so one of convenience.
cdegroot is offline   Reply With Quote
Old   June 18, 2013, 04:58
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
The main fact about the geometric multigrid is that, by discretizing the problem on each grid level, the non-linearity is not lost, say, for Navier-Stokes equations. I don't know if for linear problems there is yet some advantage in the geometric approach.
sbaffini is offline   Reply With Quote
Old   June 18, 2013, 06:03
duri
duri is on a distinguished road
Geometric multigrid can be used for both implicit and explicit solvers. Geometric multigrid construction is quite difficult for unstructured meshes. There are many ways to construct coarser grid for GMG. I have coded agglomeration technique for GMG which is quite generic. In case of anisotropy coarse grid construction plays an important role. There is no issue of linearity and non-linearity in case of geometric multigrid, as only the mesh changes but the system is still non-linear. There may be loss in restriction and prolongation operators (not sure of this).
Algebraic multigrid can be applied only for implicit methods. Algebraic method works on the matrix with the spirit of geometric multigrid concept. Since matrix operation is linear, AMG is basically linear. AMG is easy to implement doesn't need complex geometry coarsening. Anisotropy can be controlled by selecting the appropriate coarse level matrix.
duri is offline   Reply With Quote
GAMG = geometric algebraic multigrid? schmittp54 OpenFOAM Programming & Development 1 December 11, 2010 08:25
Grid Block Interface / Algebraic Multigrid Harun CFX 0 August 5, 2007 17:06
Black Box Algebraic Multigrid Neazen Main CFD Forum 0 June 4, 2007 08:10
Seeking Algebraic Multigrid Code Anna Main CFD Forum 1 May 11, 2006 21:05
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
