Solution of SOD Shock Tube Problem by using HARTEN Modified Flux TVD Scheme
Old   December 13, 2012, 01:40
Default Solution of SOD Shock Tube Problem by using HARTEN Modified Flux TVD Scheme
xue sheng is on a distinguished road
I am solving 1D shock tube SOD problem by using Harten modified flux TVD scheme. My code is stable till CFL less than 0.6, after that it is unstable.
It should be stable till CFL less than 1.
-1=<x<0 P=1, RHO=1, V=0
0=<x<1 P=0.1, RHO=0.125, V=0
I have following question,
1. How should calculate Time Step Size (DT)? Is this formula correct?
DT = (CFL x DX)/Cmax
2. How should calculate DX? Is this formula correct?
DX=L/(200) where L = 2 (201=Grid points)
3. How should calculate Cmax? Is this formula correct?
Cmax=0
Do i=1 to 200
C=DSQRT(GAMA*Pressure(i)/Density(i))
Cmax=DMAX1(C,Cmax)
Continue
Anyone have solved this problem by using Harten modified flux TVD scheme?
xue sheng is offline   Reply With Quote
Old   December 13, 2012, 04:20
Praveen. C
praveen is on a distinguished road
You must also include fluid velocity. It might increase the wave speed
C = ABS(V(i)) + DSQRT(GAMA*Pressure(i)/Density(i))
praveen is offline   Reply With Quote
Old   December 13, 2012, 05:23
Thanks for correction.
But it would further decrease CFL criterion.
HARTEN TVD scheme should be stable below CFL <1.
But in my case it is stable around CFL<0.5.
May you please point out the reason?
Old   December 13, 2012, 05:31
Praveen. C
As I wrote your CFL condition is wrong. You must use largest wave speed to compute time step which is what I wrote in my last post.
Old   December 13, 2012, 06:11
Thanks.
After your recommended correction Its working well.
Now my Harten modified flux TVD scheme, ROE scheme, and LAX_WENDROFF scheme Code working well till CFL <1.
But my HARTEN-YEE TVD scheme code is stable till CFL<0.6. After that it become unstable.
May you please inform me that HARTEN modified flux TVD scheme and HARTEN-YEE TVD scheme has same CFL restriction or different?
I think both have same CFL restriction. But in my code HARTEN-YEE become unstable at CFL>0.6.
Old   August 27, 2022, 08:06
javeria
javeria is on a distinguished road
can u please share your codes
javeria is offline   Reply With Quote
analytical solution of 1D shock tube problem ma Main CFD Forum 10 May 11, 2015 06:20
Sod shock tube problem with real gas effects ganesh Main CFD Forum 0 October 17, 2006 02:22
SOD shock tube problem Luuk Main CFD Forum 3 September 6, 2005 06:08
help: analysis solution of gas-water sod problem gooo Main CFD Forum 0 April 19, 2005 02:05
Shock tube problem ger Main CFD Forum 1 September 24, 2003 08:41
