heat realease in wall by surface reaction (FLUENT)
Old   March 17, 2006, 17:32
Default heat realease in wall by surface reaction (FLUENT)
Marie-Anne
I am confused about which boundary conditions to choose for the wall where a surface reaction that releases heat takes place. If I choose constant temperature, then the fact that the wall should be heated is lost. If I choose zero heat flux, then it heats too much because it is considered as adiabatic. Thanks for any advice or previous experience on that.
Marie-Anne
Old   March 17, 2006, 17:47
Default Re: heat realease in wall by surface reaction (FLU
Andrew Hayes
I believe that would be a constant heat flux bc, as long as your reaction is exothermic. You have to know the heating value of the reaction
Old   March 18, 2006, 01:36
Marie Anne
Thanks Andrew but I believe that knowing the enthalpy of formation, fluent computes itself the heat produced by the reaction. I just dont know where this heat goes and how to tell Fluent it heats the wall.
Thank you
Marie Anne
Old   March 18, 2006, 07:59
Andrew Mettler Hayes
when you set up the boundary condition for the wall you can set it up as a constant heat flux. you just have to know how much heat is being released. Though, I have never done any reaction stuff. When I do a constant heat flux in fluent I set up a surface in Gambit that I can define as a 'constant heat flux' in Fluent - sort of hard to explain via the net.
Old   March 20, 2006, 10:15
RoM
Another option is to use the convection bc with a high htc (>1000). In this case the free stream temperature is almost equal to the outer wall temperature of your domain. This approach is good if you have already measured vaules for outer wall temperature.
RoM
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 05:36
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Species transport wall surface rxn phillerup Main CFD Forum 0 May 29, 2009 10:38
wall surface reaction Razvan FLUENT 0 April 5, 2005 06:10
