FFT for the Poisson equation
Old   July 29, 1999, 08:31
Default FFT for the Poisson equation
Marco Ellero
I would like to have some reference about the problem of resolution of a Poisson equation in a box, with Dirichlet or (better) Neumann boundary condition, by use of FFT.
Old   July 29, 1999, 11:12
Default Re: FFT for the Poisson equation
Patrick Godon
The use of FFT to solve differential equations are not restricted to the Poisson equations (used a lot in Astrophysics), but also to solve all kind of PDEs. These are called the spectral methods, where the FFT is used just to compute the derivatives (or also the intergral) and the equations are solved either in the Physical space or in the spectral space.
See Canuto, Hussaini, Quarteroni and Zang, 1988, Spectral Methods in Fluid Dynamics (New York: Springer Verlag) - a very good book indeed.
Good luck,
Patrick
FFT solver for Poisson equation mranji1 Main CFD Forum 1 November 16, 2009 02:12
orlandi code for poisson equation with FFT ( paid tutorial) HaKu Main CFD Forum 0 June 29, 2009 16:40
Poisson equation solved with FFT HaKu Main CFD Forum 3 June 5, 2009 00:17
Poisson Equation in CFD Maciej Matyka Main CFD Forum 9 November 10, 2004 12:30
Poisson equation vs continuity equation DJ Main CFD Forum 1 August 5, 2004 21:01
