calculation at rotating coordinates
Old   July 29, 1999, 07:16
Default calculation at rotating coordinates
JYPark
I am converting the code used at fixed coordinates to the code at rotating coordinates to analysis flow in the turbomachinery. I use the absolute velocity components at the rotating coordinates and Van Leer's flux vector splitting and implicit euler backward time marching method. I am searching the references which explain the procedure in detail. If you know the references, please let me know. Thanks very much in advance.
Old   July 29, 1999, 11:08
Default Re: calculation at rotating coordinates
Hongjun Li
The difference b/t fixed and rotating code is the governing equations. The numerical schemes can be exactly the same. So, all you have to do is to rewrite the governing equations in rotating frame of coordinate in terms of relative velocities (not absolute velocity). In fact there are only two additional terms in the momentum equations: the centrifugal force and the Coriolis force terms; the continuity equation has the same form; and in the energy equation, you may need to use rothalpy rather than enthalpy. As soon as you have the correct equations, you may insert the additional terms into the existing code. Sorry, I do not have any public reference to give you. I wrote some detailed reports but they have proprietray information inside so they are for internal use only.
For general information on equations in rotation frame of reference, you may read "Numerical Computation of Internal and External Flows: by Hirsch, Wiley-Intersciency, 1988. (Ch. 1, Sec. 1.4).
Old   August 5, 1999, 01:28
Timothy Cowan
Check out the following paper:
Kandil and Chuang, "Unsteady Transonic Airfoil Computation Using Implicit Euler Scheme on Body-Fixed Grid," AIAA Journal, Vol. 27, No. 8.
These authors have written several papers (in addition to the above) on this subject. It should at least get you started...
-Tim
Old   August 14, 1999, 19:55
Apurva Shukla
I am also working on turbomachinery flow simulation. I will suggest a paper by B. Lakshminarayana in ASME Journal of Fluid Mechanics, 1991, Frreman Schoolar lecture, I donot remember the month, but U can easilt locate them. You will get a good information & philosophy to start with.
Good Luck
Apurv
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
flow calculation in rotating blade passages jrb Main CFD Forum 1 December 9, 2007 23:09
Warning 097- AB Siemens 6 November 15, 2004 05:41
Rotating coordinates in CFX 4 P.Fonteijn CFX 0 July 9, 2002 17:46
Calculation in cylindrical coordinates Franz Wingelhofer CFX 0 December 28, 1999 08:46
