langrange interpolation and derivative enquiry
Old   March 15, 2006, 19:44
Default langrange interpolation and derivative enquiry
zonexo
hi,
i was reading a paper which uses one-dimensional Lagrange interpolation. Points A,B,D,E,C,P all lie along a line. Functional values at A,B,D,E are known. Dp/d(line)=0 at C. How can one use these info to get the value at P? I thought langrange interpolation only uses functional values. How do I make use of the dp/d(line)=0 at C?
Thank you
Old   March 15, 2006, 23:03
Default Re: langrange interpolation and derivative enquiry
Praveen. C
You have 5 data. Write a polynomial with 5 degrees of freedom. You get 5 equations for the 5 dof. Solve for them. Then evaluate polynomial at P to get the value there.
Old   March 16, 2006, 20:19
zonexo
hi, thanks. r u taking abt polynomial interpolation? ie y=a0+a1*x+a2*x^2+a3*x^3+a4*x^4+a5*x^5 and differentiate to get dy/dx=a1+2*a2*x ....
however, i'm referring to lagrange interpolation. the author of the paper has given the hint that
dp/dn|_C=a1*p_P+a2*p_B+a3*p_A+a4*p_D+a5*p_E=0
and i'm told to get a1-5 using standard Lagrangian interpolation procedure. So how do I go about it?
thanks
Two dimensional cubic spline interpolation flappingwing2008 Main CFD Forum 5 December 22, 2016 22:55
help on interpolation Jean-François Main CFD Forum 1 May 28, 2003 13:11
