constant surface heat flux
Old   March 15, 2006, 14:13
Default constant surface heat flux
Andrew Hayes
given the equation
Tm(x) = Tm(i) + (q"*P*x)/(mdot*Cp)
If I know my mdot can I make the equation into a local temperature for a finite difference scheme? For example, if I have 25 nodes perpindicular to the flow, can I take the mdot and divide it by 25 and assume the each node gets 1/25 of the total mdot and then calculate the Temp at that node? My problem is that I have boundary conditions at each of the 4 walls that contain no reference to the flow velocity. So, when I change velocities my temperature profile does not change. I can get the temperature at each of the boundaries, but I am having trouble getting the temperature within the grid. I wanted to take the above equation and use it for the temperature above the heated wall and then go from there.
thanks
Old   March 15, 2006, 21:42
Default Re: constant surface heat flux
ztdep
what is your problem i just do not understand what the meaning of mdot ! since you have know the temerature at the boundary, why you have problem within grid.
Old   March 15, 2006, 23:24
Andrew Mettler Hayes
mdot is mass flow rate - sorry
I have a problem inside the grid because I have velocities. My boundary conditions do not involve velocity, so when I change velocities my temperatures don't change.
thanks
Old   March 16, 2006, 01:00
ztdep
for the fully developed channel flow, the dimensionless temperature is constant, it has no relation with velocity
Old   March 16, 2006, 08:19
yes, I know that. But, if I change my velocity for an entirely new problem my temperatures do not change. For example, if I want to compare the heat transfer characteristics at a Re of 10 and an Re of 1000. In my current set-up I get the same answer regardless.
HOW TO APPLY CONSTANT HEAT FLUX OVER WALL OF TUBE K.VENKATACHALAPATHI FLUENT 6 December 28, 2015 06:58
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 13:01
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
BC for constant heat flux saidi Main CFD Forum 2 July 17, 1998 16:02
